FatblockFord
Does anyone know if a 90-93 column is the same as a 88? Specifically the length?
OK, I’ll take a look at the knee bolster as well.These are both non tilt steering wheels and I have an idea this could be the problem.View attachment 2965
That is awesome. Thank you for the help. I’ll check the measurements on my setup and see. That could be an easy solution as I was thinking about how to make a piece to fill that gap.I'm thinking the only solution to fill that gap is the trim ring for a tilt steering wheel. I went out and measured mine to see if any of thes measurement would work for you.
View attachment 2977 View attachment 2978
