1988 Steering Column
Pull on the shaft it will move in or out to any length you need. If it doesn't then remove the column and spray some WD-40 down around the bearing at the end of the column.
FatblockFord
The situation I have is I bought an 88 that has a Grant wheel an 90-93 column shroud (sort of hanging in place), which leaves a big gap between the shroud and wheel. So I bought the 88 non tilt shroud, but when lining it up to the ignition switch and turn signal it will not clear the dash. It’s like the column is inset to far.
FatblockFord
Ok. Thanks for the help. I need to get under the dash and see if there is an obvious reason why things aren’t lining up.
These are both non tilt steering wheels and I have an idea this could be the problem.View attachment 2965
OK, I’ll take a look at the knee bolster as well.
The gauge cover has a rectangular cutout just above the column shroud. Like maybe it was a column shift automatic originally??? Makes me feel like the column has been swapped and I’ve got a bunch of mismatched parts.
Thanks for the help!
FatblockFord
I will get some. I actually pulled it apart last night to try and determine what I am working with.
I think I have a 90-93 column, knee bolster, column shroud and gauge cluster shroud.
FatblockFord
I saved the pics as small so hopefully you can see them clear enough. It looks like they installed a 90-93 column, instrument cluster, cluster shroud, knee bolster and column shroud. That all actually works together ok. A little repair and paint and I think it will look good. However, how do you fill the void from the big square backed factory wheel when running a Grant, or other aftermarket wheel?
I'm thinking the only solution to fill that gap is the trim ring for a tilt steering wheel. I went out and measured mine to see if any of thes measurement would work for you.
FatblockFord
View attachment 2977 View attachment 2978
That is awesome. Thank you for the help. I’ll check the measurements on my setup and see. That could be an easy solution as I was thinking about how to make a piece to fill that gap.
Thanks again.
