Another option is to remove the entire pedal box, which actually might be a tad easier. It's just the four bolts on the brake booster, the clip for the brake booster arm on the brake pedal and the two bolts on the steering column.
On a brighter note, I was able to spend some time doing much needed cosmetic work. I replaced the banged-up hood with a nice used one I got a while back. I painted the underside and even cleaned up the latch parts.
Hard to tell from the pic, but I painted the underside "bright regatta blue", which was the original paint color. The rest will eventually be painted to match. I hope to get the door jams and engine bay areas done soon. I figure it might save me a little when it goes to the paint shop.
Crank is ok. been sitting a long time. Probably would need some work, but it was pulled from a running motor.Looks like a nice score!
Is that crank still good?
I just bought a Kawasaki Vulcan 1500 to part out today. Its nearly impossible keeping money in the Mustang fund. My wife spends it nearly as fast as I make it.![]()
I can relate, since I use to have that issue. But not anymore! ;-)Looks like a nice score!
Nice. Where are you ordering from?I ordered new upholstery. Since my car is grey & Blue on both the inside and outside, I ordered blue & grey tweed upholstery. Should look stock, but unique!
Agreed! I've had pretty good luck with most of the reproduction stuff I've used. I bet it's decent quality, and probably a LOT better than worn out factory stuff. My seats are borderline condition. Not really bad enough to replace, but nowhere near perfect.If it's good quality , that's going to be awesome.
via Tapatalk
