Single outlet line lock
I traded for a BandM line lock.Upon looking it over I notice it only has one output port.Have any of you used one of these this style by placing a T to join the front brake lines and run a line into the solenoid?
I've never used or installed a line lock, but I figured it would get installed between the master cylinder and the prop valve. That way, you only need the one in/out.
Update It worked out fine after a bought the right fittings(metric)I bought a kit from hurst with lines and fittings.It was pretty much useless(all sae fittings)Jegs sales kit just for mustangs with the proper fittings (metric to sae).You will just need a few short brake lines.This saves money going this route also.
