Thank you! It is the WOT relay! I found the relay itself online but I've been looking everywhere for the connector to wire in.Not positive on this, but you may be looking at the WOT (wide open throttle) relay for the AC. You might try doing an internet search for that and see what you can find.
I believe it is! It seems to be the same as the fuel pump one on there also! I ordered it. Hopefully it will work. Thank you so much!Would this be it?View attachment 3025
