Loud Squeak During Startup
erikcpod
Hey I'm 18 and my 1993 5.0 is my first "project car." It started to make a very loud squeak during startup and it's now having idling issues.
ddrewes11
Did the idling issues happen only after the squeaking started? Squeaking could be the drive belt getting old, might be slipping which could cause the idling issue. But they could be unrelated as well.
Check for leaks too. A drop of power steering fluid or coolant here and there can make them sing. If everything looks nice and dry and the belt tension looks good, remove the belt and turn the pulleys by hand. They should all feel smooth when you turn them. If bearings, for instance, in your alternator go bad, they can lock up and cause a squeal.
And don't forget the tensioner. It should be keeping the belt pretty tight and spring back with authority when you crank on it. They do tend to weaken over time.
erikcpod
Yeah the bad idling started happening once it started squeaking and I already put a new belt on. I also have brand new power steering and alternator because they went out a few months ago. Thanks for the help so far I'll try that stuff tomorrow morning.
