Inline fuel pump
Cajjar
I built a 2.3na motor and now it is a 2.3t I'm installing a walboro 255 inline pump and I'm wondering if the stock wires would be fine to use or should I run a larger wire from the battery? Also if I can use the same wires which color goes to the positive prong on the pump. Thanks in advance.
Is your setup a "return" type?
IMO, that's a lot of fuel pump, and with a return system which the pump stays running... Factory wires may get warm, probably not hot.
I suggest you run the setup and measure amp draw. Use inline meter or a clamp meter on "DC" setting.
Are you using an impact switch inline? I suggest you do, in the event the car is in a severe accident, will shut the pump off.
I'm not a fan of factory wiring but, it works for the most part on non modified applications.
You need a voltmeter to DC test light to ensure proper polarity when connecting to any DC or AC system.
Cajjar
Yeah I'm using the holley super sniper efi system and am running a fuel pressure regulator with a return. So what exactly does testing polarity mean is that checking which side is hot and which isnt?
Yes.
If the pump is polarity specific, you definitely want to run it in the correct rotation direction.
