fastronald
Can some of you measure the width between your Rear Shock towers where they meet the trunk floor............does your car measure out at 38 1/2" distance? this is the angle where tower and trunk floor actually meet.
I suggest a "double adjuster" system.I guess if I pursue my idea of building a true "Bolt In" rear shock tower brace.....it would be a case by case basis as the distance requires. Use 3'/4 i.d. pipe and angle stock with 3/8" grade eight bolts.
May I suggest you use "thinwall" chromoly tubing with "weld in" threaded inserts?Thanks.......I may try that..would use a heavy threaded rod and jam nuts to secure it in position..then line it up and drill two mounting holes and a bolt in. If this works out well.....IK would offer you one to test for the price of shipping.
