marcod13
Hi all, i have a 1985 3.8 CFI and I went to go and remove the battery today and figured I’d also replace the battery terminal cables because they looked a little weathered. As I was doing so, I applied too much pressure on one of the hoses from the PCV valve. I then heard a small snap noise and noticed I cracked a a valve that looks like a PCV valve but the lower body isn’t metal. It’s plastic. It was plugged into what looks like a canister under the battery. Does anyone know what this part is called? I will try to fix it with some epoxy weld if I can’t source the part. Appreciate the help! Apologies if this is in the wrong section.
