3.73's or 4.10's?
Discussion in '1987 -1993 Mustang GT' started by 87gtslowstang, Jun 28, 2014.
  1. 87gtslowstang
    87gtslowstang New Member
    2
    1
    Have a dd 87 gt with a relatively stock 5.0 and a stock aod.Just wondering what gears i would be happier with-3.73's or 4.10's?Has ac delete,smog delete,bbk shorty headers,bbk x-pipe,flow master 40 series mufflers,and a sve cai.
    Blown347 likes this.
  2. lyonmt
    lyonmt Active Member
    104
    43
    28
    Depends on how much you drive. 4.10's will give you more "jump" off the line, but will run at a higher RPM on the highway. So if this is a daily driver, something you use on the highway or a touring car, I would go with 3.73's. If it's a weekend car for beating on, a drag car or for cruising around town, the 4.10's would be recommended.
  3. Kang
    Kang New Member
    11
    6
    "They " say use 3,73s for a manual transmission and 4;10s for automatics. I have a manual and I am running 3:55s ( I didn't want to go to steep for highway driving).
  4. ALMOST STOCK
    ALMOST STOCK Active Member
    265
    158
    43
    I've read the same thing many times over the years, and like you with a manual I also went 3.55 for that exact same reason..... and I'm happy with the 3.55's
  5. 83stang
    83stang Member
    60
    22
    8
    Like above stated 3:55 or 3:73s if its a daily driver 4;11 if its a weekend toy. I'm running 3:73 and its pretty dang quick, although I'm running a 5 spd.
  6. Foxtrot92
    Foxtrot92 New Member
    9
    1
    I'm running 3.73's with my current bolt on upgrades and 303 cam and im very pleased with the performance. I'm currently in the process of big performance upgrades but will probably remain with 3.73's (no really planning for an all out drag car). The general rule of thumb with most setups is 3.73's you will run between 2,000 and 2,300 rpm's at 60 mph and usually around 2,700 on 4.10's with a 5 spd. like everyone has said... it's all about what your plans are for the car.
    research, research, and more research. you can never ask too many questions or know too much about what you're doing before you do it. and I've come to find out that it's not only the numbers that matter at the end of the day. word of mouth and personal experience is some of the best knowledge you can obtain when building on any vehicle
    best of luck :)
  7. 87_notchfox
    87_notchfox just another notch among the rest lol...
    587
    185
    43
    i got 3.73's on my coupe with a T-5 and i like it. its got enough get up with them and not bad on gas. going to use the same on my 89 auto coupe if i dont fine 4.10's lol
  8. FoxBodyMustangs
    FoxBodyMustangs Administrator Staff Member
    730
    250
    63
    I think you will be happy with 3.73 in an Auto for DD.. I just dropped 3.55 and could have went a little bit higher...
    87_notchfox likes this.
  9. SVT K9
    SVT K9 New Member
    1
    5 speed with 3.55s. About perfect, somewhat of a daily driver. More of a weekend ripper
