Welcome to the site! Car sounds nasty! I may pick your brain some time soon, since I've been contemplating a 460 fox!
If you're building a street car that you occasionally drag race, you may want to reconsider your cubic inch selection. A well thought out/built 466-472 cubic inch engine can easily eclipse the 600-650hp range and still be streetable. 514-521 cubic inch engines will easily eclipse the 700hp=750hp range. My car is primarily a street car. This particular 466 is around 11.5:1 and runs on 93 octane pump gas with only 30 deg. of timing. It can be a complete handful on the street. I haven't had it to the track with this combo yet, but there is no reason why this thing shouldn't run low 10's-high 9's naturally aspirated.I've so wanted to do a 557 build with AFR A460 or Kasse heads one day myself
You won't be disappointed if you do. I built this car from the ground up by myself. I would be happy to answer any questions. As far as an engine build, I'm on a specific website for the 429-460 based engines...the engine builders on this sight are legit and really know these engines. Best place to hang out and lurk/ask for info.Welcome to the site! Car sounds nasty ! I may pick your brain some time soon, since I've been contemplating a 460 fox!
