Nothing wrong with the 85 4 barrel motor. Iirc, 85 was an odd year. Maybe roller cam on some and flat tappet on others? Regardless, you'll probably want to know if it's a roller or not before you decide on purchasing it. I would usually opt for a roller motor if given the option. I say "usually" because some of the early blocks (both 302 and 351w) are considered stronger. Of course, they will be flat-tappet... but that's easily remedied by installing link-bar lifters. The downside is that the link-bar lifters are pricey. Expect to pay $350+ and don't even think about buying the cheap ones on ebay/Amazon. They're garbage.
If you're building a mild street car, the roller lifter/spider/dog bone setup is fine. Link-bar style is a little more heavy duty for race application, as the dog-bones can break when over stressed.
The biggest problem with flat tappet motors is that today's oil isn't good for them. You will have to use zinc additives. There is some argument for using certain diesel oils, but it's questionable these days and manufacturers could change the formula and you don't even know it.
Easiest way to tell is by pulling the intake. The lifter valley will have a spider and dog bones to hold the lifters in position. Some early roller motors were "roller ready", but had flat tappet cams. Again, the lifter valley will tell you. You'll see two threaded holes in the middle, which are used to hold down the spider. Non-roller blocks do not have the holes.... only non-threaded oil drain holes. If you want a factory roller motor, don't waste money on a non-roller unless it's a deal you can't pass up (IE: a fresh build with performance parts for cheap). Rollers are easy to find in stock form and cheap.
Another thing to note is that the 85 heads are crap for performance. In fact, most factory 302/351w heads are crap. A popular swap is to grab a 5.0 from an explorer. They should have gt40 or gt40p heads, which have decent flow numbers. (Research spark plug clearance issues with gt40p heads). Earlier e5,e6, and e7 (85, 86, 87-95ish) heads aren't worth the time and money if you are looking to make a little power. If you just want a reliable cruiser, then they're fine. You might even come across some fresh rebuilds for dirt cheap. Some poor saps spent good money having them fixed up before they found out they flow like crap!
Hopefully this helps you and I'm not just rehashing stuff you already know!
