FatBoyGrimm
I recently purchased my first fox body, it has some modifications, AFR heads, BBk throttle body, Trickflow Intake, and a mild street cam(not sure which kind or what degree lobe). I am having a problem With the car surging at idle. I have cleaned the MAF sensor which helped a little and after retraining the idle it still surges for about 45 sec. then balances out around 800 rpms.I can even turn the A/C on, but the second i have to stop with the rpm's at 1500 or higher the car shuts off. and it only does it when the A/C is on. otherwise it drives fine. I am trying to fix this issue with out deleting the A/C. has anyone had this issue. and does anyone know a way to fix it
