John2002
I don't know if anyone has had this problem with their system but I finnally fixed mine. It has been on for about 2 years now and it seems because of the design of the muffle on to the tail pipe sections I never could get a secure seal with that 1 1/4 inch single piece band clamp. It seems to not have enough bite on the collar coming from the muffler exhaust outlet to seal onto the tail pipes inlets. I bought another set of band clamps thinking I strecthed out the ones that came with the kit ( Flowmaster American Thunder cat back ) Well I spent about 30 minutes on my back with a single hack saw blade and cut two 1 inch slices back from the egde of the exhaust outlet collar towards the muffler so the clamp could squeeze the collar down to the tail pipe inlets. I did one at the top and one at the bottom of both exhaust outlet collars. If anyone is planning on buying a cat back system with those one piece band clamps and installing it in the near future then cut those 1 inch long slots about a 1/4 inch wide before you get started on the install.
Good luck...
Good luck...
