Forsale crower carb cam # 15514
got a used crower 15514 cam that i pulled out of a 306 block i bought unknown miles some small surface rust but can be cleaned of i got most of it off bu wiping it. i have no use for it because is for carb not efi. specs 110 lobe center, duration @ .050 234/240 gross lift with 1.6 rockers .54/.545, level 4 cam, low rpm 2700 peak hp 6200 redline at 6500. spec from crower http://www.crower.com/ford-302-h-o-hydraulic-roller-cam-1969-up-232hr239.html
. make m a good offer dont need it
