gt18t
Greetings every one! Checking in from Michigan on my Fox body. I've had it for three years now, and it has gone through some major transformations.
Here's some of the mods:
1984 mustang
Cobra roller motor bored out to a 306 (80,000 on motor)
Ac delete kit
Bbk cold air kit
Bbk 70 mil throttle body
Bbk equal length shorty headers
REAL cobra intake. ( Not just cobra plate)
Bbk fuel pump
Under drive pulley kit
Aftermarket H pipe
Flow master after axel dump mufflers
Transmission
Tremmic T5 trans
Rebuilt at 60,000. Shifts cleanly, no slop
SVE short throw shifter
Steeda aluminum clutch quadrant
New Ford motorcraft drive shaft
Rear end
Upgraded 8.8 rear end. (Came with 7.5)
3.73 gear
LSD
Rear end was reconditioned by the ring and pinion shop in waterford (shims, seals, etc 2014)
Tubular control arm kit with urethane bushings. (Done this year 2014)
Suspension
Griggs springs
Bushings replaced in 2013
Exterior
T top
Seals replaced, only Leaks around window. Windows need to be adjusted to come up higher (small gap)
SVE cobra 5 star rims. Tires still have 75 percent tread. (Car is only driven 6 months out of the year
New windshield
Paint was wheeled out by Autometric in troy earlier this year.
Interior
New carpet
Converted dash and most interior pieces from a 91 notch back.
JVC 6 inch touch screen dvd player.
Not sure where the seats came out of, but they were in a notch back, and we bolted then in.
1100 watt amp
Rockford fosgate P3 12 inch suB
More pics later.
I was going to sell, but after I started to just everything I had done, I changed my mind. Im saving for a on 3 performance turbo kit
Any other suggestions would be great!
1984 mustang
Ac delete kit
Bbk cold air kit
Bbk fuel pump
Aftermarket H pipe
Transmission
Tremmic T5 trans
Rear end
3.73 gear
LSD
Suspension
Griggs springs
Exterior
T top
New windshield
Interior
New carpet
1100 watt amp
More pics later.
