Easy fix..
For Code 33 you need to replace your EVR that fixed my code 33
For my Code 41 / 91 I did the below... Turnout to be my 19 wire not in the right position..
41 - System Indicates Lean -passenger side(R), No O2 Sensor Switching Detected. always lean -passenger side(CM)
91 - System Indicates Lean -driver side(R), No O2 Sensor Switching Detected. always lean -driver side(CM)
For Code 41 and 91 do a continuity test from pin 49 at the ECM connector, ECM disconnected, to a good ground source, the resistance reading should be equal/less than 5 ohms
Codes 41/91 (Lean Condition) specific tests:
For codes 41/91 (lean condition), it is always recommended to check the condition of the HEGO GND circuit (pin 49 at ECM connector), a bad/open ground circuit will cause lean readings from the O2 sensors. The HEGO GND is an Orange wire, with a ring connector, that goes bolted to the back of the driver side cylinder head. Identified as item #19 in the following harness diagram.
'86-'93 O2 sensors are 3-wire setups, eventhough the following chart shows a 4-wire setup, the tests can be performed as specified. 3-wire sensors DO NOT use a SIG RTN circuit....
Once you fix the one's I have identified the rest will go away..
