JakeMeek
I used to run a passenger side low mount alternator bracket when i was running the headers out the back but i just put front exits on for easier maintenance (and they sound badass) and that bracket no longer works because the alternator runs into the headers. the headers dont sit very low and exit right out the fender in front of the front tires. A higher mounting bracket would fix this but then the belt would rub on my electric water pump. kindve out of ideas , just figured id take a shot at this and see if anyone is running a similar setup or had this problem. if this gets any attention ill go out and get some pictures of the setup.
