joemonkeyman99
(1989 gt vert 5.0 HO 5 speed) okay so i had some bad connectors for all light switches and steering wheel plugs which i replaced with some better ones (spliced in). for some reason after i did that my fuel pump stopped running with the key. I hooked 12v up to the wire from the relay to the pump and it kicked on. I hard wired it to a 12v with key on and it turned over but only ran with starter fluid. I figured it needed to go down from 12 to a lower voltage so i disconected my DIY fix of course. Ive been trying to figure this out for a while now and to no end. Ive been thinking a bad ground maybe at the computer. I did check the grounds i could find but couldnt see anything bad. idk maybe i missed something
