1986 Jalapeño SVO
Turbo4
Been part of this and Wickedstangs and have had lots of Mustang. Picked this car up a couple years ago. Probably paid too much for it. Needed a catalytic converter but afterward passed smog just fine.
From there I changed the shocks because they had some cheap kyb for the original valves koni red’s
Took it to Streets of Willow for a track day and noticed that my steering was getting caught up when turning it. Turned out it was the inner bearing for the steering wheel which turns out you can’t find anywhere so had to buy a new column for it.
At the same time I got a momo steering wheel for it
Once that was done I decided I wanted different wheels with bigger brakes
Drove that for a while and then decided I wanted to do a cam and restore interior with new a/c parts Which is where I’m at now.
Then I noticed that my valve stem seals were bad so swapped those out too.
Still need to put new cam in and swap in roller followers. With new exhaust manifold and bigger turbo with the ported lower and gutted upper intake. Also have lots of wiring to fix and new fans to wire up with a controller.
View attachment 7212View attachment 7213View attachment 7214View attachment 7215View attachment 7217
I replaced all the valve seals on my 2.3 last year. They had gotten very hard over setting for 15 years. I did it with the cam in. I made an air adapter to put compressed air into the cylinders to hold the valves up and used a valve spring compression tool to release the keepers.
I did the same but I damaged one of them putting them in because they are the hard metal ones. So I actually ordered the right tool. Should have top end buttoned up next week
It’s a nerve wracking job but my air adapter worked well and the valves never gave me any trouble during the process.
Went to go run a bigger relay for a 255lph fuel pump and discovered somebody in the past had wired in trailer lights. I have no idea why and there wasn’t a hitch when I bought it. Although it might be related to why some wire is bypassed for the current fuel relay.
Finally finished installing front control arms. Went with Maximum Motorsports SN95 length arms with stock offset. This keeps the original track width of the SVO. Also bolted on my 99-04 cobra calipers with custom brackets to run 12” rotors. This lets me keep my 16” wheels and I can always go larger 13” later if I choose to. Last things to do for front suspension is get the steering all hooked up to the spindles and get the front swaybar back in.
