Trans fluid t-5
Maxwell
I was in the process of changing my trans fluid in Jolene well when I got to the parts store they say to use ATF but that doesn't make any sense in a manual gearbox anybody have any other info on this?
Maxwell
Huh, good piece of information to know thank u It's definitely appreciated . And as far as additives go do u recommend putting any in with the ATF to thicken it up a little?
G force sells an additive that I put in my trans. It's good stuff. But the trans is made to run on just ATF.
G-force GF-2000 is the fluid. Their website says you can run just this in the tranny. The shop that built my trans said use 1 quart of it with whatever ATF you run. So that's what i do.
Maxwell
Thank u ill have to get some. Also the rear diff calls for 90 weight can I just put 75-90 limited slip in there? I don't see why not just figured I'd ask lol :p
I'd use Ford Racing, Summit, Jeg's and Late Model Restoration all sell it. And most likely the parts dept at your local Ford Dealer.
Sent from my SPH-M820-BST using Tapatalk 2
