Rear control arms confusion.
HarveyLX
I have a 1990 LX convertible. I plan to install the Eiback Pro-Kit springs and dampers. Engine mods in the future would be under 400HP.
My question is on replacing the rear control arms. All my research has resulted in a head ache and no decision.haha
Should I keep stock (new) upper control arms? (I understand about the rubber bushings thinking )
Should I replace the lowers with adjustable arms to maintain proper rear end alignment after installing lower springs?
Is it a good idea to install torque box reinforcement brackets regardless?
Car is only street driven but I do like DRIVING windy roads.
Thanks!
I suggest replacing CA's with adjustable aftermarket just for the tuneability.
My torque box wasn't spot welded from the factory very well. In fact, 50% of the welds connected nothing. I suggest you insect yours, then decide if you're gonna need reinforcing.
Erkenbrand
I learned the hard way to at least replace the uppers control arms with adjustable. After many upgrades my pinion angle was off, and I had to adjust the rear angle. Which meant replacing the tubular uppers I had just installed with an adjustable set.
