Radio harness question
Discussion in 'Interior Tech' started by Notchback91, Jan 20, 2018.
  1. Notchback91
    Notchback91 New Member
    2
    Hello, I have a 91 LX Coupe, the car came to me with the radio harness pigtails cut off. It seems there is 2 separate harness where the radio should be. Trying to connect a radio but I have far to many wires going on here. Anyone familiar with these or can anyone post a picture of your connectors so I can see what each wire goes too? Both harness have at least 1 or 2 12v constant wires. Thank you. I will see if I can pin a picture in this thread not sure how.
  2. Bob Mathis
    Bob Mathis New Member
    17
    5
    Mine is the same way. I have a factor wiring diagram. If I can help let me know.
  3. Notchback91
    2
    Yeah that would be some help
  4. Bob Mathis
    17
    5
    I will see if I can san it. It is better big.
  5. broncojunkie
    broncojunkie Active Member
    539
    167
    43
    I'm not home but if I were, I could take a look at my 88. Should be close. I have a receiver just sitting in the opening, not hooked up. Won't be home for a couple weeks.
    But I figured I would chime in with this. On almost all of my old Fords of this era, I simply find a constant 12v, switched 12v, and ground. Run all new speaker wiring and bypass the factory stuff. The factory speaker wiring always gave me problems... even when these cars were newer. Plus, the wires are really too small for anything other than the most gutless system. I even had to do this to my 98gt a couple years ago. The factory speaker wires shorted out and fried a nice pioneer deck.
