Thanks for the response. I have, it was backed all the way off, I feel like the tension spring for the park break is pulling to hard. The top of the shoes are pulling away from the seats even though all the springs are correct according to this diagram.Have you tried back off the adjuster assembly?View attachment 2572
I did not, the ones I put on are advised as 69". I would assume the longer ones if incorrect would create the opposite effect. But maybe not I don't know what the original was because they were cut when I got it.Did you know that the make 2 different lengths of parking brake cables.. (67.880) part # BC9315 is the shorter one and a longer one .. (68.750)
part# BC984498 is it a possibility that you are using the shorter cable.
https://www.rockauto.com/en/catalog...00,brake+&+wheel+hub,parking+brake+cable,1696
