John2002
that small tube where the long pivot bolt goes through the bracket seems to be splitting. is there a way to remove and replace it?
If you mean the end of it on the inside of the tube (against the alternator) it's supposed to look like that. It also I believe isn't a solid tube, but has a break all the way through it.that small tube where the long pivot bolt goes through the bracket seems to be splitting. is there a way to remove and replace it?
there is suppose to be a dowel pin that goes in the center...I took 7 pictures, these were the better to the bunch...
