Need some advice?
I recently just bought a 90 lx 5.0 hatchback. The motor definitely needs some tlc. I'm looking for the best but cheapest way to build my motor up. I really don't know alot about all the little things like injectors and different compression. I've been looking at getting a trick flow top end kit?? Any suggestions on that or suggestions on a better one.. It would be appreciated if someone could write a good detailed list of what all I would need. Thank you
A trickflow top end kit is the way to go simply because they did all the
research for you to come up with the best combination of parts to produce
a very good output increase. I think it is the best bang for the buck, but don't
forget about the rear gears very impotant to really benefit from the power increase.
I prefer 3:55 gears for the street.
