Ford 302 or 255 windsor
Discussion in '1979-1986 Four Eyed Mustangs' started by Peter Heenan, Jun 2, 2018.
  1. Peter Heenan
    Peter Heenan New Member
    2
    1
    1
    Hello its Pete from down under . I have a 66 stang with an 80s motor. Iam not sure what the exact yr is . Engine no behind starter reads EOAE DC3 20. Heads have a metal brace stamp 3k14. There are also some numbers on the corners on the outside of the heads 45 and 61. Any help would be appreciated in identyfing exactly what year the motor is.
    FoxBodyMustangs likes this.
  2. ALMOST STOCK
    ALMOST STOCK Active Member
    265
    158
    43
    If it's just the rear main that is leaking there is no reason to rebild the engine, just replace the rear main.
  3. Peter Heenan
    2
    1
    1
    Thx for that . Yes pretty keen to know what the yr the block is as well because i think they changed from 2 peice to one peice around 82. Also trying to establish if i have a 255 block.
