gaberator567
i have an 88 5.0 with a starting issues it cranks but doesn't start it has spark going from the ignition coil to the distributer and distributer to the plugs also has an injector pulse.it had fuel pressure at first after replacing the pump but the pump would stay on even with the key in the run or accessory mode now it has lost all fuel pressure. i have already replaced the fuel pump, pump relay and fuel filter. i have narrowed it down to a fuel problem because it will start and stay running on starter fluid. any ideas?
