stangspeed91
Hello I'm new to the group. I've had my 91' Mustang for 23 years been modifying over this time. Recently added BBK SSI intake manifold, 205 aluminum heads, BBK fuel rails, 24lb injectors and new Mass air. Mostly it runs and sounds good but when I push the engine it misfires on the right side. I checked spark plugs and wires but I do not see any carbon or other type of build up. Also, I have changed the solenoid and ignition coil.
I have a air/fuel meter that normally runs between 14 to 15. Without changing all 4 injectors on the right side, is there a way to tell which one is causing the misfire?
