Cleveland swap
Discussion in 'Welcome New Members' started by 361C, Jul 7, 2018.
Tags:
  1. 361C
    361C New Member
    1
    I swapped a Cleveland in my 89. What kind of alternator and power steering brackets do I need. Thank you
  2. broncojunkie
    broncojunkie Active Member
    708
    203
    43
    Since you've done the swap, you're probably a step ahead the rest of us already! Not many people doing this swap, but I'm not sure why. I'm a big fan of clevo power and they seem right at home, tucked down inside a nice fox!
    Are you wanting to go with a serpentine belt setup or v-belt? If you are wanting to go serpentine and you have crank and water pump pulleys already, March Performance makes an aftermarket kit that could probably be adapted to work. You would just need the correct spacers and belt length. It uses an adjustment rod instead of spring loaded tensioner.
