SOLD 1993 SSP Texas Highway Patrol coupe! 5-speed
Status
Not open for further replies.
Mnstr50
This is the real deal folks! A true Texas Highway Patrol coupe!
Exterior is a dark grey, the interior is ruby. Manual windows, manual door locks, power mirrors (not functioning), cruise control (not functioning). AC is all new, and functioning, however, the HVAC control panel needs to be replaced. No stereo in the car, however I will be purchasing a delete panel. 5-speed is rebuilt (with receipt evidence). The clutch cable will need to be replaced, and I will have one installed (Steeda with firewall adjust) prior to selling the car. The door map pockets are sagging, and the driver side door arm rest is missing (I will purchase and install the replacements).
SSP options;
Driver side trunk release
Single key for ignition and doors
Additional ground straps
5-speed
160-mph speedometer
Factory 10-hole wheels, clean title, spent most of its life in Texas and Arizona. Driver seat has wear, paint is pretty ugly. The dash has some of the Patrol car mounting brackets, radiator core support is solid! Underpinnings are solid! New Power steering pump, new power steering rack.
SSP Mustang technical details and history;
http://sspmustang.org
Texas Police radiator tag
Ground straps
Trunk release
160mph speedo
Additional Glass mount
Chris 6O2-6l8-8l54
$5,200 obo
Mnstr50
I've already purchased a laundry lost of parts.
New tires 205/60-15
New shocks/struts Monroe
American muscle 1.5" lowering springs
Moog ball joints
Offset steering rack bushings
Poly lower control arm bushings
Stereo delete
Arm rest delete
Window cranks
Installed HVAC control knobs
Steeda Clutch cable, and firewall quadrant
Installed a factory airbox w/new filter
Installed Motorcraft platinum plugs
Installed Motorcraft cap
Installed Motorcraft rotor
Installed ACDelco plug wires
Fan clutch
Fan blade
Goodyear gatorback belt
Anchor Motor mounts
Anchor trans mount
**Passed emissions with flying colors
Installed the new door arm rest pads
Installed the new ashtray door
Installed motorcraft PCV valve with grommet, and filter screen
Mnstr50
Updated photos, also new lifetime warranty tint done yesterday;
Factory air box replaced,
Tint is medium all the way around
Arm rest pads replaced,
Ashtray door installed, and arm rest delete install, along with stereo delete;
HVAC knobs replaced and unit repaired;
Mnstr50
New motor mounts installed, new fan clutch and fan blade installed. Lowering springs are now in (American Muscle 1.5" drop) along with caster/camber plates.
Caster/camber plates
Status
