Hi All
The starter on my 86 LX 5.0 recently stuck on, so I installed a new solenoid, ignition switch, and ignition relay in the column, car is now totally dead with 14 volts at the battery. Can't even get headlights.. Any ideas?
Thanks-Tom
Thanks, will do.Check the ground strap connection from the engine to the firewall. In general, check all ground connections for corrosion
