Switched hot that stays hot when cranking?
Erkenbrand
This is driving me crazy. I have a 1980, and have installed the whole Holley Sniper package. It turns out the wire I'm using for switched hot doesn't stay hot when cranking. The problem is - I can't find one that does. I've been pinning out from the ignition, and not having any luck.
Any pointers? This was originally a turbo 4 car, but now has a carb'd 302 from an 83 GT so the wiring when I got the car was already a bit of a mess.
Thanks!
I suggest you tap off the blower fan circuit.
The only issue that could become serious, is if the sniper system needs more amps as rpm increase.
If this is true, I strongly suggest you make a "stand alone" circuit with 15 amp fuse or breaker.
Good luck
Erkenbrand
Thanks! I ended up just making a standalone circuit. I figure it will also be part of my theft prevention system. ;-)
