Well, I thought my battery drain issue was fixed, but I went out today and the battery was dead again. I threw a light tester on it and sure enough, there was a drain on it. Went through the process of pulling fuses and relays, one at a time. No luck. I then tried unhooking the alternator (same thing I tried last time) and this time, it made a small difference. Still had a drain issue, so I pulled the smaller wires off the starter relay and touched them one at a time. There were 2 wires that completed the circuit...these two:
Either they are black or the color is faded to the point where you can't really tell. I may have to dig a little, but I believe they both go into fusible links.
I also believe at least one of them lead to a relay on the back of the driver's side shock tower.
It's hard to access due to the harness being in the way, so I apologize for the poor pic.
Anyway, I can't seem to find anything in the Haynes book for these wires or the relay. Any insight to what I'm looking at here?
