I new there was an issue with the filler neck on this mustang I bought 3 months back. The filler neck was never attached inside the fiuel door. So I bought a bunch of the gaskets that I knew were torn and took it apart.
I have everything ready to go back together and like I said before something is wrong with the way the filler neck attaches to the over flow plastic box that attaches to the quarter panel.
There is a metal ring on the filler neck and a separate ring with a gasket that I assume should attach to the plastic box.
Does anyone have a drawing the way this should go together. The over flow plastic box opening is larger the the ring on the filler neck. And maybe there is a missing piece that was attached from through the fuel door.
I have attached all the parts I have for this. Maybe something is missing. It was never attached at the fuel door opening.
Thank you in advance
1991 Mustang GT
1967 Plymouth Barracuda
1991 Mustang GT
