EEC IV Module: where is it hiding?
Sawmill
Old and tired
I'm looking to swap in a known good module, and I've looked all over the under hood, even with my glasses on. Is the module under the dash somewhere?
The EEC is behind the kick panel on the passenger side.
EEC Removal
Remove the battery ground cable. Remove the passenger kick panel. You will probably need to remove the lower door strip to get the kick panel out. The kick panel is held on by a screw towards the back and a 'mushroom' fastener towards the front. Remove the EEC-IV retaining screw to the lower right of the computer. Remove the EEC connector using a 10mm wrench. Clear any wires/relays out of the way and slide the computer out.EEC Right hand Side.jpg
