Crankcase Pressure?
A little thing me and all my buddies do on all our builds, this Moroso plate works wonders on venting crankcase pressure. You run a 12an line from the plate to a vented oil catch can.
BTW you have to run a mechanical fuel pump timing chain cover.
Yeah it works wonders if you don't want 4 breathers on your valve covers. It's a must if your running low tension oil rings. The way I see it oil contamination is the #1 octane killer on an engine so why not give it some help to vent properly:)
