Hello,
Trying to diagnose a crank/no-start issue. Starting with fuel. When I turn the key the fuel pump makes the prime noise and fuel pressure goes up to about 20 (just prime no crank) but then rapidly goes down to zero. I Pulled the fuel delivery line off after the fuel filter, getting fuel. Pulled the fuel delivery line (after where the autometer gauge mounts to the line), getting fuel. I’m trying to figure out if the drop in fuel pressure after prime is the reason for the no start. If so, what can the issue be? The inertia switch works, I popped it and got no fuel pressure whatsoever then reset and got the fuel pressure as described above.
I am going to try to attach the video of what it is doing.
Any help would be greatly appreciated.
Daniel
Daniel
