mannymendez25
I am having a coolant leak in my 92 5.0. It seems to be leaking in the back of the engine. As you can see the bell housing is rusty since the coolant has a bit of rust. Any ideas of where this could be coming from?
The problem is that just replace that one from the stock heater core which was working just fine . with the LMR one, I figured it's 10 yrs old and I got the dash out why not replace it. I put the hose on , didn't put the hose clamps on ........... and pulled the one hose off again to straighten it more and that's when the copper pipe pulled out. So I had to pull the dash back out and install another heater core.Damn! Hopefully you had planned to replace it before that happened..
Yes.so those are heater core pipes coming through the firewall?
God bless you! Just finished this job and if I had to do it again it’s going to the shop. Glad to see that you got that type of age from the LMR one. That’s the same one I got.The problem is that just replace that one from the stock heater core which was working just fine . with the LMR one, I figured it's 10 yrs old and I got the dash out why not replace it. I put the hose on , didn't put the hose clamps on ........... and pulled the one hose off again to straighten it more and that's when the copper pipe pulled out. So I had to pull the dash back out and install another heater core.
View attachment 3394 View attachment 3395
The original heater core was 10 yrs old and I decided to change it because of the age, put the LMR heater core in and didn't make it 1 day, bought a Ford replacement and it's been in since 2000 .God bless you! Just finished this job and if I had to do it again it’s going to the shop. Glad to see that you got that type of age from the LMR one. That’s the same one I got.
Well damn!! That sucks! I wasn’t able to find an OEM Ford replacement when I did mine a few months ago…now I will be worrying about this LMR one. UghYes.
