clutch cable firewall mount
Nvsssnake
Has anyone repaired the mounting screw for the clutch cable thru the firewall. The stock screw is now too small, I need to remount my for the manual adjuster. the original screw hole has been stripped out.
Can you just spin it around a bit and drill a new hole? On one of my cars, I simply found another thicker screw I had lying around and it worked perfectly.
