whiteponygirl89
Well after several phone calls and emails, I am now getting a brand new set of tires!
The only problem, the dealer has none and will have to source them. Hoping I don't have the
same problem with the new ones letters browning too. Will definitely take before and after pics.
Old tires will be sent back to them.
I just have to pay mounting and balancing-about $50 so not complaining.
This is a huge WIDESPREAD problem with these tires.
Mine were bought in 4/2019 and have less than 1000 miles on them.
Should of know something was up as the blue did NOT want to come off.
They put in an ozone agent that is supposed to help the rubber and its impact
on the enviroment.
Their answer was to use steel wool or a brillo pad and if that doesn't work a wire
brush then 400 grit sandpaper-REALLY?!
Tiny wires break off, embed in the letters, and will eventually rust, then I would have
speckled letters. Just some bleche white has always done the trick.
Apparently, Michellin has bought out BF Goodrich, I am hoping this will not be the demise of Radial T/A's.
on the enviroment.
