Mo Imzi
Hi, my stock injectors need to be replaced and I decided to go with 24lb injectors. Will I need a MAF sensor as well? Or can I run without it? Thanks!
Thank you! I decided to go with 24’s because I have plans on upgrading the engine down the line. I plan on building it slowly, but would like heads, cam, and intake. At the moment (as far as I know) the engine is stock. The previous owner had a cold air intake, however. My Fox is a 92!Welcome from NC! Why did you decide on 24lb injectors and not go with the stock 19lb injectors? What type of modifications have been done to the engine? What year is your fox?
