1993 FOX CP ROAD COURSE CAR STILL STRRET LEGALISH
my92tealcp
TIME TO SELL MY FOX CP. VERY LONG LIST OF MODS. GRIGGS RACING TUBE CROSS MEMBER MOVED AS FAR FORWARD AS POSSIBLE, MOTOR MOVED BACK AS FAR AS POSSIBLE. GREAT FRONT TO REAR TRANSFER. TUBULAR CONTROL ARMS WITH OFFSET. MANY DIFFERENT COILOVER SPRINGS, MMS RACE STRUTS BRAND NEW NOT INSTALLED, REAR SUSPENSION IS A STOCK 8.8 WITH NEW 3:73 GEARS AND HD POSI, HARDEND AXLES WITH STUDS, GLOBAL WEST LOWER ADJ CONTROL ARMS, MMS ADJ PANHARD BAR, GLOBAL WEST TORQUE ARM, BRAND NEW IN THE BOX MMS COILOVERS, WITH RACE SPRINGS AND CONVERSION KIT. 25 GAL FUEL CELL, WILWOOD 13" 6 PISTON FRONT BRAKES, PBR BIG ROTOR REAR BRAKES, ADJ BIAS, FULL PERIMITER ROLL CAGE TIED TO THE FRONT STRUT TOWER AND LOWER BOXES, TIED INTO THE REAR SUSPENSION AND THE BOXED IN TORQUE BOXES. 2 SPARCO EVO 2 SEATS, 6 POINT HARNESES, DRIVERS SEAT HAS AN ADJ SEAT BACK BRACE, DRIVE AND PASS SEATS ADJ FRONT TO BACK. COOL AIR HELMET COOLER AND COOL SUIT COOLER SYSTEMS. IN CAR LAP TIMER, FULL SET OF MECHANICAL GAUGES, MOTOR IS A DSS LOW COMP BLOWER MOTOR BLOCK WITH SPYDER PREP HEADS, CARTECH BLOWER BOX INTAKE, 80MM MAF, 42 LB INJ. VORTEC BLOWER WITH AFTER COOLER, MOTOR AT 5PSI IS AROUND 550 HP, 8PSI IS AROUND 625 HP. TRANS IS BAD BROKE 3RD GEAR, NOT SURE IF INSTALLING A 6 SPEED OR IF SOMEONE WANTS IT W/O TRANS AND USE ONE OF THEIR CHOICE THAT IS FINE. A FULL SET OF FRONT AND REAR MAIER RACING WIDE BODY FENDERS AND A ORIGINAL STEEDA FRONT LOWER AIR DAM. HAS A SET OF RACE RIMS AND TONS OF EXTRAS GO WITH, CALIPERS, PADS, 6 SETS OF COILOVER SPRINGS, NEW IN THE BOX MMS ADJ REAR SWAY BAR, SURE I AM FORGETTING STUFF.
ASKING $20K
