1989 5.0 fuel line help.
Jossuelote
I'm having some trouble with the fuel lines. It looks like mine got pinched at the nylon where they meet the hardline and I got the car in a place where I dont have access to 120v sockets to use a heat gun to put some nylon lines back on. Is there an alternative thats safe enough to use but doesn't require heat shrinking or anything where id need heat or electricity? I've seen people say you can use fuel pressure hoses and fuel line clamps but I've also read that the fuel pressure is high enough to cause leaks and that sometimes clamps won't hold to the pressure causing the lines to just come off completely.
