1982 mustang air cleaner fabrication question
82FOXSTANG
So I have an 82 with a factory hood scoop. And would like to change the air cleaner to seal against the hood and make the scoop into basically a cold air intake. Is there any aftermarket options to put on my 302 that would do this? I think custom making my own would be fun but I trust other people more! Thanks in advance!
You only need to fabricate or buy a carb pan made from aluminum, fiberglass or carbon fiber.
Buy some petroleum resistant 2" foam to seal the sidewall.
You will need a tool to flare the carb hole to fit the receiver flange on the carb if made from aluminum.
IMO, fabricating this is medium in difficulty and requires very little special tools.
There's a picture of a moroso pan in my build thread. My application is rear cowl induction however.
