Smoker
Discussion in 'Windsor 5.0 / 5.8 Engine Tech' started by Nick87Saleen, Apr 3, 2016.
  1. Nick87Saleen
    Nick87Saleen New Member
    i have a 1987 Saleen. Under hard acceleration and high rpm downshifts it smokes smells like oil. Any ideas what that's from?
  2. broncojunkie
    broncojunkie Active Member
    531
    165
    43
    Smoke from tailpipe or under hood?
  3. Nick87Saleen
    Tail pipes
  4. FoxBodyMustangs
    FoxBodyMustangs Administrator Staff Member
    728
    249
    43
    might be an exhaust leak at the collector or the headers... Sometimes it can also be from the valve gaskets leaking onto the headers..
  5. Nick87Saleen
    If that was the case wouldn't it smoke from under hood? The bluish/white smoke comes out of the exhaust
  6. FoxBodyMustangs
    728
    249
    43
    I thought you posted under hood, my mistake... If its bluish/white smoke that is not good.. Check your dip stick put the oil in your two finger tip and tap them together if it turns milky its a blown head gasket or something worst.. Make sure your engine is not running and don't every touch the oil while HOT...
    broncojunkie likes this.
  7. Blown347
    Blown347 Moderator Staff Member
    1,058
    546
    113
    Run to the parts store and get a block tester, it will tell you if there are combustion gases present in the coolant (I.e. A blown head gasket) that's what it sounds like to me, but it could also be that you've got a cylinder about to let go, since it's not constant smoking. Could be getting blowby from a bad cylinder when you get on it hard
