Project foxbody need help
Discussion in 'Members Build-Up Projects' started by Frankz, Jul 23, 2018.
  1. Frankz
    Frankz New Member
    i have a 1993 mustang lx 5.0 302. Has a cold air intake, full exhaust, gears, suspension, short shifter. Everything else is stock. I’m on a tight budget should I engine swap for a blueprint 347 or put a turbo in it with heads intake and cam. Which one should I do. I also put new clutch and worldclass trans
  2. Redtwilight
    Redtwilight Shinigami
    132
    61
    28
    What are your plans and goals for the car? Track oriented or just a street driver?
    You could always get the 347 now and then add the turbo later.
  3. Frankz
    Frankz New Member
    Little bit drag but mostly street but if I get the 347 I would only be able to get that that means it would be the 347 with stock intake manifold
  4. Redtwilight
    132
    61
    28
    Well that is a bit of a problem. Then if that's the case either between a 347 short block with the factory stock heads or a factory short block with aftermarket head, intake, and turbo...
    The factory heads and intake will not flow near enough for the 347. You'd probably wouldn't pick up much until they are swapped out. But it could be built now to handle whatever you'd plan to do in the future.
    The most gains then would come from the H,C,I, and Turbo swap in that case. But you'll be limited with the stock block and rotating assembly.
    Also don't forget to factor in the extra price for a larger fuel pump and injectors and the requisite tuning that would be required.
