Adam Allgire
Having some issues with the power windows. What's happening is the drivers side switches don't work at all, the passenger side does. I know the switches work though, as I tested them on the passenger side and the passenger side on the drivers side, drivers side still don't work, no switch. The door locks do work. All switches worked when on the passenger side.
Now what I have done.
1. Tested switches, they do work.
2. Used a volt meter and checked for power. I checked on the back side of the switch on the pink wire, I get 12.35 ish volts. When I press on the button, the volts drop to 4 ish, nothing else happens. There is power to the motor also.
3. Checked wiring, obviously its good, as I get power. Now I have rewired the whole car, the only OEM wiring is the power windows, mirrors, and power locks. I just ran a new power line to my fuse box. My fuse box is a Ron Francis.
I've been racking my brain for the last week, and I can't figure this out. This is the only major problem I have with the car and it can be driven. I really need the windows to work as I don't have AC at this time. Please help!!! Any advice will be helpful.
Edit: 1990 LX hatchback
