93mustanggt
I have a 93 Ford Mustang GT. It has a 5.0 in it. The only thing done to it is a cam, edelbrock carb and an intake. I have an extra 600 CFM edelbrock carb that I am wanting to do blow through mods to it. I have already looked into the TQ Float mod and I plan on doing that. The turbo I plan on running is a GT35. I'm only wanting to run 7-10 PSI. I also plan on not running a intercooler. I will keep an eye on egt's. I could use some help for fueling. What size jets do I need and if you could post a link for me, that would be helpful. My fuel pressure regulator is set at 6.5PSI. Will I need to turn it up some more since I will be pushing more air and need more fuel? Being a diesel tech, I do not know much about these carbs but I know the basics. Any links or tips would be great. If anyone needs anymore info, I will reply ASAP. Thank you.
