LX Shredder
Finally got my first real ride in my new 5.0 after spending $825 at the shop. This car is over my knowledge with modifications and the mechanic I brought it to was a disappointment. I got new power steering pump and mufflers installed. The car stalls when cold and my wideband gage is broken. Any advice or comments about my set up much appreciated?
Vortech V-1 supercharger 8 psi
Anderson style powerpipe
42lbs injectors
Lightning MAF
GT40 heads, with upgraded springs and 3 way valve job.
Scorpion 1.6 full roller rockers
Manley hardened pushrods
GT40 upper and lower intake
JCP custom cam
Accufab 70mm throttlebody and spacer
New Melling oil pump with new ARP pump drive
Aermotive stealth 340LPH fuel pump
Kirban adjustable fuel regulator
BBK O/R H pipe
Magnaflow mufflers
Gripp rear upper and lower control arms
Welded subframe connectors
Welded Panhard bar
Aluminum driveshaft
355 gears
275's and 255's Nitto
Lowered and aftermarket shocks
T5
OEM clutch
the car felt solid but the wideband gage dosn't work and I'm wondering if I should take it to a shop that knows these cars very well in northern florida? The car is strait and rust free and the interior is the black cloth color in very good condition. What you guys think of the set up and any advice on any changes?
42lbs injectors
Lightning MAF
JCP custom cam
BBK O/R H pipe
Magnaflow mufflers
Welded Panhard bar
Aluminum driveshaft
355 gears
T5
OEM clutch
